delete the unwanted patch antenna in array
Altair Community Member
Updated by Haj Hassan
i have a probelm.
When i am making an Array.
If i am using a patch antenna, and this patch antenna is in the middle.
When i make a circular patch antenna array. The origin patch antenna will stay in the middle.
How can i delete him? Or maybe shift it and make 7 another patches?!?!?!?
Thanks in advance.
Best Regards
Haj Hassan
1 - 2 of
21
OPUpdated by Haj Hassan
thank you for your help.
i have another problem.
why when i add another box for exmaple, than this box will be also automatically extended!!!!!!!!!!!
How can avoid this ?!?!?!??
Thanks in Advance
Best regards
Haj Hassan
Hi Kuzi
CADFEKO just shows the original 'base' element.
If you view the model in the postprocessor (POSTFEKO) you will not see that element.
