i am currently simulation a dipole antenna with a radius of 1.78 mm.
Unfortunately Feko allows only to make a dipole with a radius of about 1.1 mm.
How can i solve this issue?
Thanks in advance.
Best Regards
Haj Hassan
You can make the dipole from a cylinder meshed into triangles and use the edge port.
Or you could separate two cylinders by a small distance, add a short wire and still use the wire port.
