Is it possible to run Flux from Matlab, and retrieve the results directly to it without having to go through the API?
For example with COM server? Like an c = actxserver(progid)?
If so, to what ID one has to create the server?
Thanks,
Adrián
It is not possible to run Flux from Matlab with COM server, the only way is through the API.
An example is provide in the folder C:\Program Files\Altair\2022\flux\Flux\Api for a standard installation of Flux.
I hope this helps.
Best regards
Cyril Favre
