Dear all,
what is the best way to use the current solver step size of a model within the model itself for further calculation?
A minimum example would be very much appreciated!
Thank you in advance!
Christian
For those, who are interested:
I just found the block that I was looking for - SimulatorInfo from the palette Activate\ActivationOperations contains all the necessary information.
Best
In palette ActivationOperations component SimulatorInfo.
Possible infos are (according to help):
Best regards, Ronald
Just a few seconds too late ... /emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
...but with more detailed information/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20'>
Thank you, Ronald!
