Dear experts,
I'm trying to use one 'Read from txt file' block in combination with a Demux to visualize 3 columns. Unfortunately, it does not work, i.e. in Activate 2017.3 the message is: 'In the definition of block parameters: Given format is not compatible with number of requested outputs.'
Does that mean, it is not possible or do I have to change something?
Please, find attached the corresponding model and txt file.
Thank you in advance!
Christian
