I have designed a LLC converter with PSIM. As optimal values I have chosen Q=0.6 and K=4.
Boundary data:
Vin_rated=400V
Vin_min=300V
Vin_max=500V
Vout=50V
Po=3400W
f=200kHz
Now I would like to create a thermal model for this and determine the efficiency of the converter. For the mosfets I use the STW45NM50 and for the diodes the STPS200170TV1.
Now I have simulated the model again, with the appropriate thermal resistors for the different loads (300V - 500V, and load of 0.2 - 1).
The losses in the mosfets or diodes show that they are lowest at 300V, and highest at 500V, although the overall efficiency is lowest at 300V and highest at 500V. These values cannot be plausible. So I wanted to ask if my model is correct at all, and if not, what I am doing wrong.
Attached is the PSIM model and the Excel file with the determined values.
I have already read through the note application of PSIM (POWER LOSS AND EFFICIENCY CALCULATION OF RESONANT LLC CONVERTER), however I cannot find the error.
