when I go to add my ipt file into inspire cast nothing shows up. It is like my part is too small to be seen or never existed at all. Down below is my part in Autodesk inventor.
Dear @Wesley Gregory
I imported the attached file Inspire Cast and HyperMesh, but it seems that it can not import geometry.I think it would be good to test with neutral format(*.igs, *.iges and *.step.).
Can you save a file as a neutral form on the Autodesk inventor.?
Thanks,SungMoon kim
