I'd like to import MotionSolve FMU file by 1D simulation soft(Amesim).
But this Amesim compiler is 32bit.
Therefore I have to save FMU as 32bit in MotionSolve.
Is there any setting about compiler?
Hi VAL1,
At this time, MotionSolve only supports export of a 64-bit platform compatible FMU. This is because the binaries exported in the FMU from MotionSolve are built using 64-bit compilers. Are you able to use a 64-bit version of Amesim?
Thanks,
Tanuj
Thanks Tanuj,
I see, but our amesim cannot use 64 bit right now.
I have to ask admin person next update....
