I want to visualize the force (line which is drawn arbitararily) on the model surface.
Is it possible?
If it was ANSYS, I can define line and relate it to contour.
Hi naoki,
Are you looking for this option? (try below option)
Thank you
Hello Premanand,
this option is only Node,Elements,section...I want to draw line where I want to know
and make stress graph by the line. is it difficult?
I don't get you. Please can you explain it with some snap shots.
