meshing
VAL1
VAL1 Altair Community Member
I want to remesh after setting up another parameter.
how should I do?
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Hi naoki,
    You can change the surface selector to elements in the automesh panel and select the element to re-mesh and click mesh.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.02ab6a3217a062a1bb4ba6ebba9292e6.png
    Thank you
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Is your issue resolved?
    Thank you
  • VAL1
    edited June 2018
    Hi Premanand
    Thank you, but I want to mesh after create tetra mesh.(Solid mesh)
    Is it possible?
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Hi Premanand
    Is it possible?
    Sorry i didn't get you. You mean, you want to create tetra mesh after 2D mesh?
    Thank you
  • VAL1
    edited June 2018
    I mean the model has already meshed 3D.
    I want to retry the 3D mesh fineness.
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Delete the mesh and re-do it.
    Thank you
  • VAL1
    edited June 2018
    Thank you for early reply.
    How should I delete the mesh?
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Simply hide the geometry and delete the elements displayed.
    Thank you
  • VAL1
    edited June 2018
    Thank you so much.
    I have another question.
    Now I try Non-linear transient analysis.
    I want to change animation intervals, where should I change?
    I changed  TSTEP⇒ N,DT, is it not enough?
    I don't know the meaning of  NLPARM⇒NINC , NLOUT⇒NINT, they are default value.
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Prakash Pagadala is expert in Non-linear. I think he replied to your question. Please ask him, if you have any doubts about this. He will be happy to help you, don't hesitate :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Thank you
  • Altair Forum User
    Altair Forum User
    edited June 2018
    @naoki
    NINC is the implicit load sub-increments. If your NINC is 10, the load will be divided into 10 and applied in 10 increments (provided pure convergence),
    NLOUT is used to output incremental results in h3d format. Start with default value and keep SVNONCV to YES
  • VAL1
    edited June 2018
    Thank you , So in case I set 1.0s time duration in the tstep.
    and NOUT/NINT 10.
    the animation is divided 0.1s?
  • VAL1
    edited June 2018
    I have one more question
    what is the relationship between TSTE/N,DT and NOUT/NINT ?
    TSTE/N is sampling number, DT is interval?
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Yes, Dt is the time increment and N is the time step value for DT
