is it possible to have a summary export distributed among multiple tabs that has a file name with the date variable?
My summary report exports correctly into multiple tabs based on distinct value of first key with a constant file name. When I add the current date variable to the exported file name, the file is created without interpreting the value for date variable. For example, the file is created as &[mm]&[dd]&[yy]_SummaryExport.xlsx rather than 013119_SummaryExport.xlsx.
The converse is also true. I have a detail file that exports correctly with a date variable in the file name.
Thanks for any suggestions.
______________
Ann Stapanowich
Analyst - Revenue Cycle
Mission Health System
Hi Ann,I'll look into this. They are not mutually exclusive, as far as I know. Which version of Automator are you using? Is it a standard or Visual process?In the meantime, you should be able to export with a static file name, then add a distribution to include the date macro.Regards,Steve.------------------------------Steve CaielsProfessional ServiceDatawatch Corporation+44 203 868 0253-------------------------------------------------------------------------Original Message:Sent: 01-31-2019 11:10 AMFrom: Ann StapanowichSubject: Summary Report exported into multiple tabs and naming macro for date in exported file name problem is it possible to have a summary export distributed among multiple tabs that has a file name with the date variable? My summary report exports correctly into multiple tabs based on distinct value of first key with a constant file name. When I add the current date variable to the exported file name, the file is created without interpreting the value for date variable. For example, the file is created as &[mm]&[dd]&[yy]_SummaryExport.xlsx rather than 013119_SummaryExport.xlsx. The converse is also true. I have a detail file that exports correctly with a date variable in the file name. Thanks for any suggestions. ______________ Ann Stapanowich Analyst - Revenue Cycle Mission Health System This message and its attachments may contain confidential and/or legally-sensitive information that is intended for the sole use of the addressee(s). Any unauthorized review, use, disclosure, or distribution of the information contained in this message and its attachments is prohibited. If you have received this message or any of its attachments in error, please destroy all originals and copies of the same and notify the sender immediately.
We have Automator version 12.2 and Monarch version 14.2. It occurs when exporting directly from Monarch. Thanks for the work around suggestion.Ann------------------------------Ann StapanowichRevenue Cycle AnalystMission HealthAsheville NC(828) 651-4110-------------------------------------------------------------------------Original Message:Sent: 01-31-2019 12:10 PMFrom: Steve CaielsSubject: Summary Report exported into multiple tabs and naming macro for date in exported file name problemHi Ann,I'll look into this. They are not mutually exclusive, as far as I know. Which version of Automator are you using? Is it a standard or Visual process?In the meantime, you should be able to export with a static file name, then add a distribution to include the date macro.Regards,Steve.------------------------------Steve CaielsProfessional ServiceDatawatch Corporation+44 203 868 0253------------------------------Original Message:Sent: 01-31-2019 11:10 AMFrom: Ann StapanowichSubject: Summary Report exported into multiple tabs and naming macro for date in exported file name problem is it possible to have a summary export distributed among multiple tabs that has a file name with the date variable? My summary report exports correctly into multiple tabs based on distinct value of first key with a constant file name. When I add the current date variable to the exported file name, the file is created without interpreting the value for date variable. For example, the file is created as &[mm]&[dd]&[yy]_SummaryExport.xlsx rather than 013119_SummaryExport.xlsx. The converse is also true. I have a detail file that exports correctly with a date variable in the file name. Thanks for any suggestions. ______________ Ann Stapanowich Analyst - Revenue Cycle Mission Health System This message and its attachments may contain confidential and/or legally-sensitive information that is intended for the sole use of the addressee(s). Any unauthorized review, use, disclosure, or distribution of the information contained in this message and its attachments is prohibited. If you have received this message or any of its attachments in error, please destroy all originals and copies of the same and notify the sender immediately.
