Dear all,
I am going to make a python interface for my project in Flux, which I can easily change the model parameters by just changing the python code.
Could anyone give me a instruction that I can work through? Thanks so much!
Sincerely,
You will find attached PDF files for learning how to use a python script in Flux.
Best regards.
Hi, You will find attached PDF files for learning how to use a python script in Flux. Best regards.
Thanks for your imformation!
You are welcome.
