Characteristic Mode Analysis Problem
When I try to solve my model given in attachment, I can't track any mode between 4-6 GHz. The frequency step size is 20 MHz and mesh size is 1/30 lamda for center frequency. The solver works on double precision still I can't get any eigenvalue, modal significance or excitation coefficient. Thanks for the help.
Apart from this case I also have some problem about meshing a similar structure. Does anyone know why I can't mesh the given model
I get the following errors:
Error 16561: Mesher aborted - Unable to mesh face 'Union1.Face4464', probable model problem at unknown.
Error 17580: The mesher aborted abnormally while meshing Union1.
Really sorry for the missing file, I didn't know the cfx file was necessary. Here you can see the both .cfs and .cfx files
You can see where the geometry is a problem for CADFEKO from FEKO Suite 7.0 in the 3D view by zooming in where the swept edge connects to the top or bottom face:
Meshing fails because it does not know how to handle the geometry correctly. The same geometry is not a problem in FEKO 2017 or later (after geometry re-evaluation if opening the older model), so I would strongly suggest that you upgrade to the latest version. It can mesh regardless of the mesh setting (standard, fine, custom). Using the older CADFEKO, I would suggest that you try to build this face in some other way than sweeping a copied edge and hopefully that would resolve the problem.
Regarding the suspect items, I don't think that is a big problem in this case, more a nuisance. You can see suspect geometry by re-evaluating the geometry (Transform tab, Alter group, Re-evaluate). In the attached model, the suspicious settings are caused by the cylinder media settings. Somehow the geometry evaluator fails to automatically determine the correct user settings. One way to avoid the suspicious geometry is to first subtract the cylinder shapes from the rest of the geometry, then add the cylinders again (you can use copy/duplicate), set their media properties and then perform the union between the cylinders and the rest of the geometry.
Hello ynathan,
I started running the model, but if you could include the output files (.fek, .bof and .out), that would make it much easier for me to investigate.
