Hello !!!
I have an SCMR system (which contains 4 loops and two of them have lumped capacitances ) .. I am now trying to use the inscrutions on this linik but still not sure because the results are not coherent .
The link:
https://arsiconsultants.com/2018/07/23/using-lumped-components-feko/
Thank you
Inserting a capacitor onto a wire loop is very simple. Add a wire port and then add a load. You may need to split the loop and then Union the two parts again (or create multiple sections of loop which are Unioned together) to ensure you a vertex at the exact position where you want to place the port (load).
