I am using FEKO v2017.2. I am importing geometry from a .iges file. Upon importing, I would like to change the material to Copper from the FEKO library. I have changed all of the faces to 'Default', but when changing the region material, I am unable to select metallic media.
I have tried simply leaving the internal regions as free space and setting the faces to copper with a thickness greater than the penetration depth of the waves at the frequency I am using, but I receive the following warning:
WARNING 2757: A triangle is too thick as compared to the lateral dimensions for application of the skin effect approximation
See also message in the output file
Alternately, I have tried setting the faces to 'Default', and defining a dielectric material whose properties are identical to that of copper. In this case, the mesher hangs when I try to mesh the model and FEKO crashes.
Any ideas on best course of action to take?
My .cfx file is attached.
Thanks,
Alex
