I am using FEKO 2017.2.
I am getting the following error when trying to union my model together:
Error 16504: The geometry modeller encountered a problem.
Contact support with a description of what you were doing,
sending the model file (if possible), and the log file that was written to
C:\Users\bouvy\AppData\Roaming\feko\2017.2_f7bc1b75\logs\CADFEKO.PROBLEM.LOG
I've attached the model file as well as the log file specified above. Can you please help?
Thank you,
Alex
