Hi
As per my usage on HyperMesh, you could only trim geometric entity with polylines.
In the other hand, if your mesh , e.g., is associated to a surface, you could trim the surface with the polyline and the surface would be remeshed to reflect the trimming of the underlay surface.
Hope this is helpful.
Regards
