I am trying to export the volumetric mesh shown in the picture. The mesh has in total 3 bounded solids that share 2 surfaces. First I made a 2d mesh with tria in the bonding surfaces and then I created the 3d mesh with tetra based on existing meshes. I checked the type of element in the 1D/2D/3D viewer and they seem to be all 3D.
At this point, I want to export the mesh in a .cbd file. Initially, I got errors of invalid elements. Then I tried to set up an element type (figure 1) for the tetra but I still get a .cbd file with only the node position (Figure 2). I use the following command for exporting (Figure 3).
I want to export a .cbd file that has the node position, and faces, elements... that can be read by ansys.
Thank you
Alessio
