Hi, I have a question with how it works the units in hypermesh CFD. I'm doing a simulation of a car and the dimensions are in mm (MMKS) so the dimensions are similar to 4000 milimeters when I measure it, the problem is when I want to mesh the diferent parts of the car, the numbers are to high due to its units, so I tried to change the U.S which is in preferences-->sketching-->units. The question is when I change the U.S to MKS the dimensions of the car are the same when I measure it but it shoudn't, maybe it only changes in the sketch section. How it works the units and how can I change the dimensions of the model?
Thanks.
