When I first use the HyperView 2020,I found there is no Contour Plot in the upper left of the windows.
And I find it by that way.
Sadly,it isn't appeared.How I do it could appear as that show in the HyperView v13.0.
Hi Zifan,
Please make sure you have legend activated from Display Control options.
Hi Zifan, Please make sure you have legend activated from Display Control options.
Thank you so much .AND I try it in this way,but it is unuseful . Maybe there are some other problems with my computer.I guess it is without GPU.AND I have another problem needing you help.
how could i make it hidden,like it.
thank you.
Thank you so much .AND I try it in this way,but it is unuseful . Maybe there are some other problems with my computer.I guess it is without GPU.AND I have another problem needing you help. how could i make it hidden,like it. thank you.
this is a 'Note'.
Go to the browser on the left and disable/hide the 'notes'.
You can also change the text, if you want.
this is a 'Note'. Go to the browser on the left and disable/hide the 'notes'. You can also change the text, if you want.
wuwuwu,nice,you are amazing.I couldn’t express my gratitude.
