I am using the Monarch Server Automator version 14.1 to run a process. This process uses a project that looks for an import file with naming that looks like this:
OTD.DRAFT.TAPE1801042204
the numbers are the 2 digit year-month-day-time. 18-year 01-month 04-day 2204-time I have the project set to look for:
OTD.DRAFT.TAPE&[yy]&[mm]&[dd]* this allows it to pick up a file that matches todays date.
What I need is it to pick up a file with yesterdays date. I have tried adjusting the macros by -1 from each
OTD.DRAFT.TAPE&[yy-d]&[mm-d]&[dd-d]* This ended up working but picked up everyday before today that was in the file
I also tied just -1 on the day OTD.DRAFT.TAPE&[yy]&[mm]&[dd-1]* This picked up everyday before today that is in the same month and year
How can I adjust the macro to only pick up yesterdays file? I do need to take into consideration that on 01-01-19 I need to pick up 12-31-18
Thank you!
