Hello!
I have a date field that I am trying to create a formula that will add 1 month to the date. The date is in the following format: mm/dd/yyyy. I am struggling with creating a formula that adds a month to the date, but also takes into consideration a December date. if the date reads 12/15/2017 I need it to read 01/15/2018.
The other option I have (which may actually be best) is to have a formula that give me the 1st of the following month every time. for instance. If todays date is 11/22/2017, I would need it to read 12/01/2017. But it would still need to take a December date and also advance the year. so a date of 12/15/2017 would need to be 01/01/2018.
Has anyone come up with a way this can be accomplished?
Thank you
