im conducting 3 simulations of 3 models on hyper mesh. i have applied the loads and the constraints but Im not sure why when i click optistrut, nothing bis opening and there is no error warnings or anything please help if you can
Before opening HyperMesh software, delete the settings files as explained in the following post:
And, change the working directory for the .fem file and then run.
If you still face the same issue, share your .hm file if possible.
