When I run my A380 plane model which was imported from the CADFEKO component library, I come across the following error: ERROR 832: Segmentation rules have been violated (two triangles touch without a common edge).
What should I do in order to resolve this error successfully?. Actually, I want the Bi-Static RSC of a plane model A380 for my MS research work. Please help me to resolve this issue and also make its mesh surface accordingly. The model in Step format and related files are attached.
All the other files i.e. .cfx, .cfm, .fek etc are not attached due to its size which are greater than 15Mb. Your's reply should be more appreciable and acknowledged your efforts.
Thanks
