Hello everybody!
I need to fill the gap between two irregular surfaces that approximately mirror each other but don't quite match. Subsequently I need t mesh the whole thing. How can I do?
Hypermesh 2017.2
Have you tried creating a solid using the ruled option?
If two surfaces are very different, only possible solution is making a TET mesh to fill.
