Hello
Is it possible to retrieve the highest set id number that exists in the model tree?
So that when i create a new set by command it does not clash with existing set id. The idea is to create a set with 'ID = max set id +1'.
Thanks in advance
I think that do automatically in Hypermesh. When you create new set, the ID will be 'maxID + 1'
Yes Hypermesh does that for you. In case you need, try with hm_entitymaxid.
@vipin Thanks a lot that helped
@Nguyen yes in my set creation commands i need the max set id. Its for the line '*attributeupdateint sets $max_set_id 3240 1 2 0 1'
@vipin Thanks a lot that helped @Nguyen yes in my set creation commands i need the max set id. Its for the line '*attributeupdateint sets $max_set_id 3240 1 2 0 1'
Don't do that,
Use hm_latestentityid to return created set id
It could not be max id if includes are there (from version 13)
