Hi
can anybody explain me how to do Torque stiffness and bending stiffness analysis in a BIW also please send the NASTRAN setup file if possible
which will be helpful
Thanks
Hi Satyaswaroop
These documents will give you an idea about the approach
https://www.altairatc.com/india/previous-events/atc/2015/technical-presentations/OS-02-Optimization_of_the_Body-In-White_(BIW)_for_Multi_Maruti.pdf
https://pdfs.semanticscholar.org/929f/0cbbc0b5387cab50270b91d85fec0968ef8b.pdf
Hi Pranav
Thank you very much for the documents
can you help me with sample report on post processing In hyperview if possible
REgards
Satya
