*createplane plane id normal x normal y normal z base x base y base z
I would like to create a plane or vector with node ids as N1, N2, N3 and base point.
Thanks in advance!
Just write a Procedure with N1, N2, N3 & base point as arguments. Within this procedure, you compute the normal vector and call *createplane :-)
Hi Nguyen,
Thanks for the reply!
Can you help me with the codes for computing vector out of N1, N2, N3 and base point?
Thanks!
Hi Sathish,
Please refer to below posts for an idea of how to do.
how-to-get-normal-x-of-vector-created-by-two-nodes
how-to-create-a-normal-for-3-nodes
Hi Livil,
Thanks for the information!
Its helpful.
