Create the response from fuction
User: "Wisawanart"
Altair Community Member
Updated by Wisawanart
Hi
I am a new user in HyperStudy,
I faced with the error in creating process of output response, the f(x) is shown as the figure below.
Previously, I tried to fill in ((dv_2)−(5*(dv_1)^2)/(4*3.142^2)+5*dv_1/3.142−6)^2+10*(1−1/8*3.142)*cos⁡(dv_1)+10;  (when X1=dv_1, X2=dv_2)
but it is not working.
Please suggest me how to put such kind of equation in Hyperstudy.
Best regards
1 - 2 of 21
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    You can try with internal math.Refer tutorial HS-1015: Working with an Internal Math Model (Beverage Can quick start example)
    Or You can also use HyperMath to create output responses.
    Step 1: Write the HyperMath function
    Step 2: Register the HyperMath function
    Step 3: Use the HyperMath function
    User: "Diana_38240"
    Updated by Diana_38240
    I confirm you that you can create a response of f(x1,x2) as (var_2-(5*var_1^2)/(4*pi^2)+var_1/pi-6)^2+10*(1-1/8*pi)*cos(var_1)+10, where var_1 is x1 and var_2 is x2
    It works: f(1,1)=36.4
    What was not working in your case?
    Best regards
