How to create point mass in Hyperworks.
Case shown below.
Need to replicate same in Hyperworks.
its a point mass of 2500 kg. applied on defined co-ordinate system.
You can create them from Model --> Masses, that will open the mass panel, but then the specifics will vary depending on the solver profile you are using (e.g. OS CONM2, Radioss ADMAS)
