Loading abaqus result in hyperview
Hi
I made the model in Hypermesh, User profile abaqus standard3D, export it into .inp file. Then I import the .inp file into abaqus and load it. The abaqus result says analysis has completed successfully. But, when I ran it in hyperview (load model .inp file , load result .odb file) it went error.
Error messages came out but it can load the model but all in blue and yellow colour, and when I tried to see displacement etc, the colour are all blue. The hyperview could run the model but no result so I think the problem was the .odb file? But when I checked the abaqus file it says analysis has completed successfully.
Can someone tell me what’s the problem is? or what should I check again?
Thankyou
Here is the message. Hyperview 2019.1 Abaqus 14.0 and abaqus CAE2019afew things to check:
First:
Maybe your contouring just the first step of your model (which is zero loading)
Make sure your result is in the last time increment of your model. In HyperView, after contouring the model, change animation mode to 'transient', and go to the last step, as shown below.
Second:
If you got an error, which on is it? Do you have a picture?
What version of Abaqus you're running and what version of HyperView? Depending on how new is your Abaqus version you would need to update your HyperWorks to have it compatible.
Hyperview version 2019.1 Abaqus CAE 2019 and i tried abaqus 14.0 tooVersion Hyperview?
Version Abaqus solver?
According to release note of 2019.1, Hyperview can read results Abaqus 2019 without problem.
it looks like your graphic cards:
- has a outdated driver. What is your video card and driver version?
- or it is not supported by HyperWorks, so you could have visualization issues
You imported the input file from HyperMesh into Abaqus/CAE before solving in Abaqus solver? This means it has become an Abaqus parts and instance format file. If that is the case, in HyperView do not use INP. Use ODB for both model and result. This should work fine.
First:
Second:
