Hello
I am new to Altair Flux and I am trying to plot a torque-deflection curve for the following permanent disc magnet arrangement:
(Note: Infinite box is hidden)
Where:
-The two magnets inside the yellow boxes rotate about the centreline shown in the LHS screenshot above
-The yellow boxes are the mobile air regions that the two magnets move through
-The four magnets outside of these regions are fixed and interact with the rotating ones to generate a torque
I have used the rotating motion tutorial shown below to help set this simulation up (adjusting it as best as I can for the model differences):
I followed this as closely as I could when I set up my model
When I try to solve the simulation, I get the following error:
(Note: For each line that reference geometrical features, I have highlighted them in the model on the RHS)
For the faces referenced below:
- Nothing on the model is highlighted when I select them
- I cannot delete them because of their usages
- They are all used with lots of features (FaceElements, Nodes, Triantops, a few volumes), which is confusing as I cannot see them on the model or infinite box
This is most of the advanced error info:
From looking at the information provided, does anyone know what I could be doing wrong to cause these errors?
I can provide additional information if required
Thank you in Advance
Rory
