Dear Sir/Madam,
In the simulation, I set the particle size as 70um (as the minimum particle volume is 10^-12 m^3) and the particle generation rate as 1 million per second. However, I found that there are not so many particles in the geometry when completing a 1-second simulation. Therefore, I am wondering whether there is a maximum limit for the particle generation rate or particle number in the simulation.
Best Regards,
Yu
