Quality Index Element Size check: FAIL!
David_21519
David_21519 New Altair Community Member
edited May 2021 in Community Q&A
Hi All,
I am working on a thin wall component, and it is a sidewall about 600mmX2010mm. I did the meshing process caring about the geometry and its critical zones such as corners and the vicinity of the cutouts. I selected a size element of 20; however, I adjusted it to be accurate with the general sidewall dimensions. Following, I am showing the component and the message I got regarding the size element that failed to process. Has anyone known why and how can I fix it?
Thank your very much for your help!
David.
  • Jason_Craanen
    Jason_Craanen
    edited May 2021
    Hi David,
    You can adjust the min/max size for checking at the start of the tool.
Welcome!
Welcome!
