I would like to add non-perfect infinite ground plane in FEKO. it means a ground with a given conductivity and permittivity. is that possible?
thank you in advance.
You can use, under Plane/Ground, the homogeneous half space option.
This does not allow geometry in/below the ground plane.
Or the planar multilayer substrate which does.
The planar multilayer substrate is usually slower depending on the geometry that is used with it.
