what is the best terminal geometry of a coaxial cable so that to get high accuracy results ? please see the following figures
case 1 :
case 2 :
However, both results does not agree with TLM solution performed by FEKO. why? is the terminal connection geometry effect the results ??
TLM solution using transmission line model schelkunoff model for transfer impedance
