i constructed the cable shown in the attached image. the bare above wire should be electrically connected to the metallic shield. however, feko does not consider the wire and the shield surface connect even i have union them together. what do you suggest ? does there is a way to make the wire with a given radius connected to the shield surface taking in consideration the wire radius. (it means the shield surface is far from the wire center by rw (wire radius) as shown in the image).
