FE Output template & TCL variable
User: "QuyNguyenDai"
Altair Community Member
Updated by QuyNguyenDai
I'm looking a way to get the value of TCL variable from FE Output template.
In fact I would like to control template by using TCL variable, so my template has something like:
 *if([VALUE == 1])   ... *endif()  *if([VALUE != 1])   ... *endif()
Where 'VALUE' comes from TCL variable.
Any idea?
TIA,
1 - 5 of 51
    User: "tinh"
    Updated by tinh
    Hi. The way I prefer to do is to put template codes in a tcl variable and use string map to change it, like this
    set TplCodes {your codes}
    set TplCodes [string map
    1. $TplCodes]
    User: "tinh"
    Updated by tinh
    Sorry I could not type it on phone
    set TplCodes {
    set TplCodes1 [string map
    1.   $TplCodes]
    set TplCodes2 [string map
    1.   $TplCodes]
    OP
    Thanks. I'll test that.
    User: "tinh"
    Updated by tinh
    I could not type the code correctly. don't know reason
    format it by 'codes' is OK:
     set TplCodes {      *if([VALUE == 1]) ... *endif() *if([VALUE != 1]) ... *endif() } set TplCodes1 [string map [list VALUE $value1]  $TplCodes] set TplCodes2 [string map [list VALUE $value2]  $TplCodes]
    OP
    Thanks
