FIC_R_FORM => file not found, unit 50, file
Hi everyone,
I am simulating a wireless power transfer system in Flux 3D.
I have created the model and successfully solved it. However, when the solving process ends (i.e. all the steps are completed), an error is displayed:
"Failed execution: MESH_P_FLU_1_1_53.EFL"
"FIC_R_FORM => Error detected by operating system ( 29 )
FIC_R_FORM => Failed..."
It seems that Flux cannot open the file above, indeed if I try to re-open the solved project the file is corrupted and I cannot open it.
Regards
Can you sahre with us the Flux porejct before solving?
Which Flux version you use?
Best regards.
0 -
Abdessamed said:
Best regards.
Unfortunately I can't share the project, because of a NDA.
The Flux version I am using is the 2021.
Regards
0 -
Abdessamed said:
Best regards.
I assigned the air region around the system as compressible, but it seems that it corrupts the solution. Indeed if I set the region as not compressible then the project can be solved without problems.
0 -
Which type of the mouvement you use (if you use a translation you need to use a compressible mechanical set else you don't need to use compressible).
Best regards.
