We have Automator and Monarch 14.3 installed on two of our servers.
Both implement Active Directory Authentication (Monarch is linked to the Automator Server Library via SSL).
On one, the download function finds the models, on the other, it does not, although the setup should be identical.
We believe we are missing something on one of them – please assist.
Adrian Ciobanu | Proj Manager | RBC Capital Markets | 155 Wellington St W (8th Flr. North, Y Pillar) | Toronto, ON, M5V 3K7, Canada | O: 416-842-2564 | C: 416-305-0161 | adrian.ciobanu@rbccm.com
_______________________________________________________________________
This email is intended only for the use of the individual(s) to whom it is addressed and may be privileged and confidential.
Unauthorised use or disclosure is prohibited. If you receive this e-mail in error, please advise immediately and delete the original message.
This message may have been altered without your or our knowledge and the sender does not accept any liability for any errors or omissions in the message.
Ce courriel est confidentiel et protégé. L'expéditeur ne renonce pas aux droits et obligations qui s'y rapportent.
Toute diffusion, utilisation ou copie de ce message ou des renseignements qu'il contient par une personne autre que le (les) destinataire(s) désigné(s) est interdite.
Si vous recevez ce courriel par erreur, veuillez m'en aviser immédiatement, par retour de courriel ou par un autre moyen.
