Short answer is yes. Ditto will only fill in blanks with a previous value.One of the easiest workarounds would be to add a column that contains the row number and then do a reverse sort on that column and then apply the ditto function.There is currently an enhancement request to add directional control (up or down) to the ditto function and is currently targeted for version 16.1 of Data Prep Studio but I do not have a date available and is always subject to change.------------------------------Chris PorthouseSenior Implementation & Integration EngineerAltair-------------------------------------------------------------------------Original Message:Sent: 04-20-2020 04:53 PMFrom: Janet GrimsleySubject: Data Prep "Ditto"Is the Ditto function in Data Prep only able to fill down? I have a situation in which I would like to fill "UP".------------------------------Janet GrimsleyVP, Business IntelligenceThe Fauquier BankWarrenton VA(540) 349-0215------------------------------"
I like your thought process Chris! Thanks for the concept!------------------------------Janet GrimsleyVP, Business IntelligenceThe Fauquier BankWarrenton VA(540) 349-0215-------------------------------------------------------------------------Original Message:Sent: 04-21-2020 06:54 AMFrom: Chris PorthouseSubject: Data Prep "Ditto"Short answer is yes. Ditto will only fill in blanks with a previous value.One of the easiest workarounds would be to add a column that contains the row number and then do a reverse sort on that column and then apply the ditto function.There is currently an enhancement request to add directional control (up or down) to the ditto function and is currently targeted for version 16.1 of Data Prep Studio but I do not have a date available and is always subject to change.------------------------------Chris PorthouseSenior Implementation & Integration EngineerAltair------------------------------Original Message:Sent: 04-20-2020 04:53 PMFrom: Janet GrimsleySubject: Data Prep "Ditto"Is the Ditto function in Data Prep only able to fill down? I have a situation in which I would like to fill "UP".------------------------------Janet GrimsleyVP, Business IntelligenceThe Fauquier BankWarrenton VA(540) 349-0215------------------------------"
