Fixed Length Text File
User: "Janet_21505"
Altair Community Member
Updated by Janet_21505
​​I have a request for creation of a fixed length text file.  Monarch Classic can export to fixed length text files.  Does Data Prep have this capability and I am just not seeing it? Love the ease of using Data Prep to change formats easily!
Specifically this is for the FDIC Alert File which our core processing vendor can supply, BUT I have a request that requires me to create the file.  Does anyone in the community happen to have anything built for this file and would like to share?  :)
Janet Grimsley
VP, Business Intelligence
The Fauquier Bank
Warrenton VA
(540) 349-0215
1 - 1 of 11
    User: "Mo Abdolrahim"
    Accepted Answer
    Updated by Mo Abdolrahim
    Hi Janet,
    The export to fixed length text file option is not available in DPS and you cannot export a table as fixed length text file in DPS.
    You can try one of the following options:
    1- You can select the table in DPS, then click on the three bars button on the top left corner of the DPS page, and select Open in Classic Mode option.  The DPS passes the data source to the Classic.  You can then export it as fixed length text.
    2- In DPS, you can export the table as either CSV or Excel format.  Launch Monarch Classic, open the CSV or Excel file that was exported in DPS as Database in Classic.  Create an export to fixed length text file.
    Regards
    Mo
    Mahmoud Abdolrahim
    Senior Implementation & Integration Engineer
    Datawatch Corporation
    MA
    (978) 935-3840
    Original Message:
    Sent: 04-10-2020 09:08 AM
    Subject: Fixed Length Text File
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
