Hello, I have a structure that contains three mechanical sets, two sets are moving and one is fixed in a 2D magnetostatic application. Everytime I try to run the project on multiple steps it gives this error:
PBEPAV_3 => Error 49, no treated error type PBCEVL_4 => failed PBCEVL_3 => Failed PBERES_3 => failed FL5RE4 => Command not executed correctly FL5ERS => failed FL5ERS_1 => failed executeAlgo_c => failed stdcom.error.SoftwareFortranException: executeAlgo_c : Exécution impossible. Echec d'exécution at cad.core.common.error.ErrorManager.createFortranException(ErrorManager.java:170) at cad.flux.kernel.dbmanager.FGCProjectDbWrapper.executeAlgo(Native Method) at cad.flux.kernel.dbmanager.FGCProjectDbAdapter.executeAlgo(FGCProjectDbAdapter.java:910) at cad.flux.kernel.dbmanager.FGCDbManager.executeAlgo(FGCDbManager.java:151) at cad.flux.kernel.FGSupervisor.executeNativeCommand(FGSupervisor.java:2213) at cad.flux.kernel.actions.implementation.algo.project.KSolveScenarioAction.doAction(KSolveScenarioAction.java:83) at cad.core.common.dynamic.actions.UIActionManager.postAction(UIActionManager.java:145) at cad.core.kernel.KernelCommon.postAction(KernelCommon.java:347) at cad.core.kernel.Supervisor.executeJavaCommand(Supervisor.java:2885) at cad.core.kernel.Supervisor.executeCommand(Supervisor.java:2063) at cad.core.kernel.Supervisor.executeMethod(Supervisor.java:2182) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188) at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:206) at org.python.core.PyObject.__call__(PyObject.java:545) at org.python.core.PyObject.__call__(PyObject.java:551) at org.python.core.PyMethod.__call__(PyMethod.java:171) at pydb$py.executeMethod$209(pydb.py:1673) at pydb$py.call_function(pydb.py) at org.python.core.PyTableCode.call(PyTableCode.java:171) at org.python.core.PyBaseCode.call(PyBaseCode.java:171) at org.python.core.PyFunction.__call__(PyFunction.java:434) at org.python.core.PyMethod.__call__(PyMethod.java:156) at pydb$py.__call__$176(pydb.py:1444) at pydb$py.call_function(pydb.py) at org.python.core.PyTableCode.call(PyTableCode.java:171) at org.python.core.PyBaseCode.call(PyBaseCode.java:308) at org.python.core.PyBaseCode.call(PyBaseCode.java:199) at org.python.core.PyFunction.__call__(PyFunction.java:482) at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237) at org.python.core.PyMethod.__call__(PyMethod.java:228) at org.python.core.PyMethod.__call__(PyMethod.java:223) at org.python.core.PyObject.invoke(PyObject.java:3715) at org.python.core.PyInstance.instance___call__(PyInstance.java:377) at org.python.core.PyInstance.__call__(PyInstance.java:372) at org.python.core.PyObject.__call__(PyObject.java:424) at org.python.pycode._pyx9.f$0(<input>:1) at org.python.pycode._pyx9.call_function(<input>) at org.python.core.PyTableCode.call(PyTableCode.java:171) at org.python.core.PyCode.call(PyCode.java:18) at org.python.core.Py.runCode(Py.java:1625) at org.python.core.Py.exec(Py.java:1669) at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276) at cad.core.kernel.components.PythonWrapper.runCode(PythonWrapper.java:632) at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:627) at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:602) at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:597) at cad.core.kernel.components.PythonWrapper.execute(PythonWrapper.java:642) at cad.core.kernel.components.PythonWrapper.executeFunction(PythonWrapper.java:710) at cad.core.kernel.encoder.CommandServerRequestsInputPlug.executeCommand(CommandServerRequestsInputPlug.java:79) at stdcom.protocole.commandserverrequests.CommandServerRequestsRouter.executeCommand(CommandServerRequestsRouter.java:70) at stdcom.protocole.commandserverrequests.CommandServerRequestsOutputPlug.executeCommand(CommandServerRequestsOutputPlug.java:111) at cad.core.frontal.decoder.FrontalDecoder.executeCommand(FrontalDecoder.java:692) at cad.core.frontal.actions.implementation.GeneralAction.executeBox(GeneralAction.java:286) at cad.flux.frontal.actions.implementation.algo.project.FAbstractSaveAsAction.executeBox(FAbstractSaveAsAction.java:93) at cad.core.frontal.actions.implementation.GeneralAction.postAct(GeneralAction.java:254) at cad.core.frontal.actions.implementation.GeneralAction.interpret(GeneralAction.java:315) at cad.core.frontal.components.box.frontaldialog.FrontalDescriptorDialogBox.internalRun(FrontalDescriptorDialogBox.java:296) at cad.core.frontal.frontalthread.WorkerThread.executeImplementer(WorkerThread.java:226) at cad.core.frontal.frontalthread.WorkerThread.run(WorkerThread.java:274)
Which is a very ambiguous and unclear error that I can't deduce anything from. Even if I try to set two of the three mechanical sets into "fixed", the error remains the same. I tried removing one of the mechanical sets to see and the error disappears, but this is not a solution for me because I need 3 mechanical sets for my problem.
The project will run for a single value step. I am getting no errors from my geometry or physics checks. I checked my mesh also and there doesn't appear to be any clear problem in it as well.
I wonder if anybody can pinpoint the problem and help me solve it because the error code is really ambiguous for the users which is something that I really hope they improve. Getting clear errors pinpointing the errors or problems would be great and saves alot of our time.
Thanks in advance
