Hey there,
I want to compare the results of simulating an object (in this case, a wall) against the same simulation but using the RCS of the same object.
The issue comes when considering the RCS. Theres a parameter under the "Database" tab in the project parameters section. Here I tick the box that says COnsider RCS information and then import the file.
I'm using a "flat" simulation area that encompasses an area of 4x4 meters with a 0.1m resolution. However, while I get a representation of the returned signal when using the physical object (as expected), when using the RCS I just get a single "bit" or "square" (0.1x0.1 point) of the equivalent resolution on the corner of this simulation area.
What should I consider to get an accurate result?
I already tried to change the RCS azimuth value with no success. And the steps I followed were provided in an example from Altair
Thanks in advance
