why sph elements are displayed as a tetrahedron/ pryramid in hyperview.
If you are using HyperView older than 2017 you need to add the /ANIM/VERS/44 , in the engine deck, to running the RAdioss model. With this, you have the SPH with better display.
With HyperView 2019 and older you do not need to set that keyword.
Regards.
