Actually I am working on V/F control of induction motor using texas instruments high voltage kit. There are inbuilt current and voltage sensors in that kit. So to fetch the current values I have used ADC and Monitor Buffer to write and read to display the readings. But monitor buffer plots the graph with respect to samples. But i wanted it to plot with respect to time. So I am searching the logic which can plot readings of monitor buffer with respect to time. Any suggestions please.
Thanks in advance
Regards
Chinmaya
