I have exceeded 3 attempts of learning and certification quiz. Can I request resetting the quiz? The quiz is under certification>analyses examinations>non linear analysis with optistruct advanced examination>introduction to nonlinearity
I just checked the log file and it looks like that you answered all questions correctly. You should be able to proceed with the examination. Please check the next chapter (Solution Techniques) whether you can access the quiz there.
Good luck
Matthias
Hi, I just checked the log file and it looks like that you answered all questions correctly. You should be able to proceed with the examination. Please check the next chapter (Solution Techniques) whether you can access the quiz there. Good luck Matthias
I still cannot access to the next chapter (Solution Techniques)
Hi, I still cannot access to the next chapter (Solution Techniques)
Please try it again . It should work now (you may need to refresh your website)
Regards
