Hi ,
I am working on simsolid transient analysis, i done same simulation using ansys by using transient structural(no modal input), can i run same in simsolid? and how to apply the moment (time vs moment)?
The amplitude on the time function will be the multiplier for your moment.
You will need to build a modal analysis first and then transient.
please take a look at SimSolid Help page and tutorials:
Hi, You will need to build a modal analysis first and then transient. please take a look at SimSolid Help page and tutorials:
Thanks,
How to give time vs moment (N-mm) in Simsolid for transient case
Thanks, How to give time vs moment (N-mm) in Simsolid for transient case
Thanks for your information,
I have Time vs moment (rotation torque) data, how to give in above window , it has only one row,
Time N-mm
0.1 2300
0.15 2356
0.2 3234
1sec 8000
and i dont have time function , is it mandatory to give?
Thanks for your information, I have Time vs moment (rotation torque) data, how to give in above window , it has only one row, Time N-mm 0.1 2300 0.15 2356 0.2 3234 --- --- 1sec 8000 and i dont have time function , is it mandatory to give?
you need a time history, just like the tutorial mentioned in the first reply.
How to give time vs moment as mentioned above?
Thanks, How to give time vs moment as mentioned above?
The step 7 of the tutorial shows how to create a time function.
the only difference in your case, is that you can enter manually your points or import a CSV file.
Yes , i will enter the time function manually but if i give moment how it will work in simsolid,
If my time function is
0.1sec, 2000N-mm
0.2sec,3000N-mm
0.3sec,5000N-mm
and moment is 1 in z direction means, Moment is multiplication factor for time function?
