Hi everyone, I have a problem when meshing a model. It's a simple model, i adjust the mesh size but it still happen.<?xml version="1.0" encoding="UTF-8"?>
Thanks.
Is it possible to upload the .icast file ?
Meshing errors are usually due to issues in geometry. Here is the process to find which geometry needs to be corrected:
Add cores and run for solidification
Add chillers and run for solidification
By going progressively you can find out which component is creating the issue. Then the issue can come from either bad geometry itself or interface between components i.e. small gaps between components that cause the mesh to fail for the mold.
Hi, Thanks for your solution.
