Hi Everyone, I have a problem when meshing a model, this panel show up. I have adjusted the mesh size but it still happens.
Thanks.
This is most likely due to the same kind of problems you have with your other meshing error and I would recommend the same methodology:
Add cores and run for solidification
Add chillers and run for solidification
By going progressively you can find out which component is creating the issue. Then the issue can come from either bad geometry itself or interface between components i.e. small gaps between components that cause the mesh to fail for the mold.
Thanks,
Matthieu
Hi Matthieu, Thanks for your help. I have solved the problem.
